b16a3 wont rev past 3k rpm
  • b16a3 wont rev past 3k rpm
    my b16a3 starts up and idles just fine but for some reason it wont pass 3000 rpm in any gear. the car is a 92 civic si with a b16a3 swap im running a p28 ecu. i did the cel code test and the only codes i get are code 7 which is tps and a code 22 which is oil pressure sensor (for vtec) i just got another tps sensor so im going to try that when i get home anyone have any suggestions.......
    try swaping the tps with the other plug that looks the same ( cant remember what was it for )
      TPS with the IACV
      S3-R
      Stage3-Racing
        i tried doing that yesterday and checked the cel code again same 2 codes 7 & 22..... so i took off the tps and it was in pieces so this morning i went and got another tps from the junkyard hopefully its fine......
        another question when i put the wire harness on i noticed it didnt have the plug to plug the o2 sensor in or the oil pressure sensor plug as well as tge vtec solenoid plug none of them were on the wire harness and the guy who traded it to me guarenteed it was an eg ex harness......
            if none of that is there then its not a Vtec harness and that explains why you getting code 22. get a new harness with the right stuff install your new tps and that should fix your prob
            o yea you also need to connet your o2
            S3-R
            Stage3-Racing
              yea i know i have to connect the o2 sensor but the plugbis not on the harness and it doesnt look cut or anything and im not getting a cel code for the o2 sensor..... is that weird?
                Try plugging in a different ecu
                *S14 Kouki *
                  weird indeed maybe someone cut it and tape up the harness like if it was never there lol
                  S3-R
                  Stage3-Racing
                    already triedba diff. p28 nothing happened..... im lookihg to buy a p30 if anyone has 1
                      i got it you gonna love me for this one its your "ground wire" its always your "ground" lol jp
                      dam hope you fix it
                      CEL FTL
                      S3-R
                      Stage3-Racing
                        lmfao thats the first thing i checked! and.... its good
                          if you have an oil vtec pressure code u have to fix that the car is going into limp mode trying to save the car from no oil reving
                            i had the same problem on a crx and it was the disy
                              x2 but ef w/ a z6 in it same prob though
