i just put a new f1 clutch on a fidanza flywheel which i was using with a diff clutch with about 1ok on it. so my problm is its chattering really bad, i was wondering if i need to buy a new friction disk or w/e you call it. and if it will fix the problem. then my next problems is i just put new poly mounts in and car is still jumpin around alot, so cant be mounts, and when itook tranny out i rotated shaft back and forth and it felt lose and sounded like the bearings were messed up,. and when i punch the gas it like jumps back and forth then goes/ but not if im already on the gas. i think this might be my problem with the car jerking, ? ? any opinions greatly apprciated
got a few problems with teg
