Just assembled motor. Def needs a valve adjustment. So didn't let it run long at all. But it's smoking out of the breather vent on the valve cover. I just have a little filter on it, and it's smoking bad. I didn't leave the car running to see if it stops because I wanna do a valve adjustment but didn't have time. Just wondering what are some things that could cause that. So I know ahead of time when I get back to the garage if it continues to smoke. Thanks.
Smoking Help.
Sounds like you have alot of crankcase pressure. What are using for a PCV set-up? Stock PCV?13203
Is your PCV valve stuck? Hoses crimped, blocked, or pinched?13203
lsv.
ur ls with tonys b16 head. i know this because you said something about putting your itbs on. and your itr head would blow that little ls to shit. and tony said he was giving you a b16 head. and your itb will only fit a itr or b16 and you dont have another itr head. and you wouldnt sell me the ls. and you wouldnt put nitrous on your itr head unless it was on the itr block cuz you dont wanna ************ it up, so i have farther investigated the sistuation and your gunna spray a ls/vtec. with itbs.Honda sucks. Over priced junk.
Originally posted by kbrown! View Postlsv.
ur ls with tonys b16 head. i know this because you said something about putting your itbs on. and your itr head would blow that little ls to shit. and tony said he was giving you a b16 head. and your itb will only fit a itr or b16 and you dont have another itr head. and you wouldnt sell me the ls. and you wouldnt put nitrous on your itr head unless it was on the itr block cuz you dont wanna ************ it up, so i have farther investigated the sistuation and your gunna spray a ls/vtec. with itbs.13203
Originally posted by H23VTECLUDE View PostThis is staright non-sense. Installing an ITR Head or ITB's on any motor will not blow the bottom end up. Over Reving a stock LS will blow it up, not installing parts. What the hell are you talking about?!?! Not spray an ITR Head unless it's on a C5 block?????? Why?????
Originally posted by H23VTECLUDE View PostThis is staright non-sense. Installing an ITR Head or ITB's on any motor will not blow the bottom end up. Over Reving a stock LS will blow it up, not installing parts. What the hell are you talking about?!?! Not spray an ITR Head unless it's on a C5 block?????? Why?????Honda sucks. Over priced junk.
Originally posted by kbrown! View Postyou do not know him like i do. and i know that once that head goes on any motor he is going fast and beating the shit out of it. and that will blow a motor up
Originally posted by kbrown! View Postthis kid takes good care of his stuff. so that being said he wouldnt put a fully fully fully built head on a stock block. :D thanks though
