Trying to assemble my b16. And dnt have the instructions that came witht he head studs..arp. I need like a write up or something. I've searched and cnt find shit. I need to know exactly how to install them, using motor oil, and what the torque specs are. Thanks!
Head STud Help
Yeah, You should use the ARP molylube, but you can use 30 weight oil.
1.) Check Head bolt holes in block & tap only if needed
2.) Apply molylube or oil to the threads
3.) Install into the block Hand tight only
4.) Install head & make sure head does not bind on any of the studs
5.) Drop the Washers & ARP Nuts onto the Studs (Make sure you have everything lubed)
6.) Hand tighten all the ARP Nuts
7.) Torque down all the ARP Nuts from the Center 2 studs then work your way out to the sides of the head, in a criss cross action.
8: if you used ARP molycoating, Torque Nuts down to 80ft-lbs. If you used 30 weight Oil, torque Head down to 100-120ft-lbs.13203
Originally posted by H23VTECLUDE View PostYeah, You should use the ARP molylube, but you can use 30 weight oil.
Originally posted by doitpropa View Posty such a big diff in torques because of the lube???? sorry but doens't make sense to me ..... guarentee ur rite but jus wonderin13203
