b18a1 heat fluctuating
  • b18a1 heat fluctuating
    i've had post on here about my car over heating before and lil by lil as im fixing shit its getting better, all the car does now is it will run normal for 15-20 min then go up to around 3/4 never really gets all teh way to the red line, when it goes up i lose heat and then about ten minutes later it goes back down to normal temp, what is wrong with my car, kyle if you read this i need this fixed, it can probably make it to you but i dont have much money until i sell the cb7, need help bad
    Dog, have you checked ur water pump?
    and, have you made sure that your fan is turning on? if it is, is it blowing air INTO the engine compartment and not out towards the radiator?
      yea bro i had the same problem and i changed the water pump and radiator and i was good try that
      One Tire Fire !!!!!!!
        you had the exact same problem? cuz my water pump doesnt have shaft play nor is it leaking through the weep holes, you really think that could b the problem?
          replaced water pump today, its still doing it, im tired of throwing away money just gonna let someone who knows what theyre doing fix it, so anyone who reads this, i need the car fixed asap its my dd, im thinking its a warped head but not sure, i got cash in hand to anyone who knows exactly what theyre doin
            location im a mobile auto tech
              new britain
