So while racing my axle snapped...but wen i pulled it out the i noticed the tip of the axle look a lil shorter then usual....so i realizez the whole section with the teeth are stuck inside the tranny!! any ideass on how 2 get it out??? help me been workin on gettin it out all day and its moved about 1 inch
Axle Broke inside tranny!!!! HELP
Originally posted by sicksirek View Postx2 extension is def perfect u maybe talkin bout sumtihn else the hole in the tranny is like 3'' wide the extension is like 1/4'' - 1/2''
Originally posted by JDM8o9 View PostMaybe take like nut and weld that to the broken piece and pull it out
Your gonna need something thin enough to go around the diff. pin, but yet thick enough to not bend when struck with the hammer. If all else fails, pull tranny out, & take apart.13203
it's out i went there today and took it out 4 dollar carbon rod from home depot 3 feet long thin grinded one end down a lil bit and then took the dead blow to it and it popped out with ease. wayne one axle to put in and your on your way.860 member #18
puerto roc #1
Cosa nostra
ASAPRadio.net
