Search in B Series Tech only
Technical Forums
B Series Tech
Type-r Wont Start In CRX??!!! HELP
Mr.Ek.Hatch
Dec 2008
04-06-2009, 11:01 AM
Mr.Ek.Hatch
06-22-2009, 07:59 PM
ManTyme
Oct 2008
04-06-2009, 11:04 AM
bump for a poor mans type r
injen78
Mar 2008
04-06-2009, 11:21 AM
main relay
!!!!!ThE GoOd DiE YoUnG!!!!!
sicksirek
Mar 2009
04-06-2009, 12:59 PM
Well if the starter is clickin do the battery have enough power?
JDMEGVTEC
Mar 2008
04-06-2009, 01:17 PM
sicksirek
i was thinkin the same
POS civic
Feb 2009
04-06-2009, 02:17 PM
Lol well first you need a battery that works...
Mr.Ek.Hatch
Dec 2008
04-06-2009, 06:57 PM
battery is good.... found the problem, gorund was doing very bad contact, had to re-run the ground for the motor
louie25
Apr 2009
04-06-2009, 07:04 PM
First of all did u check your spark on every cylinder?
How did u do the swap? . What harness did u used ?
Do u have fuel ...
Mr.Ek.Hatch
Dec 2008
04-08-2009, 03:32 PM
thanks evryone... i had a faulty ground for sum reason... and my starter wire dat goes to the realy box thing was loose...
civicefsohc89
Dec 2008
05-07-2009, 08:17 PM
also check to see there is a fuse under the dash that is called alternator selonoid valve had sme prob and for some reaso changed that fuse and that was the prob so check that
92EG692
Jun 2008
05-08-2009, 07:44 PM
i had that same thing happen to a da a while back... i was goin crazy!!!
