b-series no spark
  • b-series no spark
    2000 civic ex
    not getting spark at the dizzy, replaced it with a spankin new one still nothing. changed out the starter.. nothing.
    car was running perfectly fine then just shut off and died on me. any ideas?
    i checked all my grounds ( thermostat housing, valvecover, tranny)
    dizzy was completely replaced.
    i didnt check wires or plugs because its just not getting sparky at the dizzy
    only thing i haven't chckd yet is the ecu becuase i dont have another to swap out no one around my area has a obd2b car
    im telling you its your tie rod end lol but ill try to get the ecu form ant tomorrow after i get out of my ged and if its nice out wanna work on my car
      yea dood thts fine
        main relay????
          i should mention its a 00 civic ex.
            coil?
            or dizzy but i hear stock honda coils are garbage nd will jus strand u at sumpoint in the cars life
              coil is located inside the dizzy which was replaced with a copmletely new dizzy
                its bc ur car is gayDM..jk..:eek:...yo hit me up
                  ok just checked everything again this morning. im getting WEAK spark. car cranks but does not start
                    i called u but ur phone is off
                      when did u call me???
                        earlier....ur phopne is off
                          confirmed im getting spark. i can smell fuel and i unpluged the FPR and fuel came out. i also checked all my fuses. spark plugs replaced. dizzy was replaced but i put my old one back in because it works too. spark plug wires seem to be okay. 3 grounds are good. trans, tstat, valvecover. there is gas in the car.
                            does the motor turn over strong like it should or is it slugish?
                            NHSWAPS13203 > *
                              jumped the intake cam 180* all fixed now tho
