ok so i bought a 93 gsr distributor and re wired it and the car runs now but i have no rpm gauge now.....or speedometer.....and its weak so must be the wrong distributor idk.....should i just take it off and put like a del sol b16 internals in....becuase idk if the 1.8 gsr internals are making the car run different then the 1.6 ones will
rpm problem now
yea i think u guys are right i pulled it off....my problem was i matched the colors and i hear your not supposed to so i just re-wired the whole thing heres the diagram i used....tomm ill have too install it and see if its right......
i didnt go by that diagram up top because a few ppl said to match the colors and most of them did match but there was 2 white wires and u had to look for the bigger 1....well i ran those white wires both ways they can be....1 way wont start....and the other way will start but no gauges again...so somehwere in the same colored wires somethings wrong...and im not even sure if that diagram applies to me because when i ran it that way everything looked messed up
Originally posted by artymillz View Posti didnt go by that diagram up top because a few ppl said to match the colors and most of them did match but there was 2 white wires and u had to look for the bigger 1....well i ran those white wires both ways they can be....1 way wont start....and the other way will start but no gauges again...so somehwere in the same colored wires somethings wrong...and im not even sure if that diagram applies to me because when i ran it that way everything looked messed up13203cripple member : PR.I.P NICK A.K.A NHswaps13203 FOREVER
Originally posted by artymillz View Postwould the distributor effect the rpm and speedometer gauges ? cuz they dont work at all.....i just updated this....my sdpeedo works just no rpms
You need to find a wire diagram from both harness' your using and then wire it, color matching might not work.Greatness is only 1,320 ft. away!!!
