Whats up CTV, I have a couple questions about RMS and Gain control (high vs low) to the audio guys on the site. Im running an Alpine deck with an Alpine plug-and-play power pack amp which converts the headunit amp to 45 rms per channel. Im also running 4 Type S 6 1/2s that have a rms rating of 80. So im wondering if ill run into an issues by having a lower rms rating from the amp than the speakers. I heard of people recommending matching or exceeding the rating. Also, the amp has a low and high gain switch on the back and have no clue what to set it at. Any info and advice would definetely help out, thanks in advance.
Audio question: need advice on RMS and Gain control
you'll have no problems doing so as long as you arent clipping power isnt the cause of speakers blowing clipping is and set your amp to full pass rather than just high i've been messing with that lately and high gives it more of the higher range of fqs and full pass will throw some midbass in there
