i installed a radio in my car everything is connected right it works fiine when car is not on all the way but when i turn on car nd step on gas snds lik i have a supercaherger lol it whistles it comes threw the speakers... dnt kno wat is help me out thnxx
Need help
I've had this problem in my DC. But never had it in my DA. Turns out that my crossover was bad 'cause when I removed it the noise went away, still had some engine noise though. You could have a ground loop or something. Read about it on Google. Also, since you have an amp, make sure you run the remote wire with the power wire on one side of the car and the RCA's on the other side of the car. Unless you have like Stinger wires or something then it doesn't matter as they are shielded. I could come take a look at it for you if you aren't too far lol. bannaHidin' out
