no power to amp
  • #16
    Do you have a cheap test light ?
    860 member #18
    puerto roc #1
    Cosa nostra
    ASAPRadio.net
    • #17
      Just read it again, u said the when u jumper the remote side to a 12v power source it turns on fine?
      96-ek hatch b20vtec - daily
      • #18
        Iv seen the remote signal on decks go bad.. Most decks come with more than 1 acc power wire, if u have a decent deck there should be 1 wire for remote and 1 wire for power antenna. U can use the power antenna wire see if it turns back on.. good luck.. If it dosnt come on from that and it comes on if u jumper it, the deck acc power source is shot. I used to install stereos for Boomer McCloud awhile back
        • #19
          Yea i used a test light just found 1 in my garage today.the remote wire is shot.i just spliced the remote from the amp to the red power wire
          Ef hatch sold
          Db7 blew up
          Em2 sold
          Db1 traded
          Ek fodo daily/project
          • #20
            yeah do that and run a switch on the remote wire so that way you wont kill your battery that would be my 2cents
            • #21
              It actually turns on & off connected to the red.i had wired it to the yellow but it was on even when the car was off
              Ef hatch sold
              Db7 blew up
              Em2 sold
              Db1 traded
              • #22
                maybe your harness is a little different try wiring it to the blue wire usually thats the remote
                • #23
                  it will, yellow is memory, red is key'd opperated power orange (if u have it) is for the dimmer.. most dont have it anymore. Is there another blue wire on the back of the unit?
                  • #24
                    If there is, use that instead, so when u turn ur radio off it turns off the amp or amps aswell
                    • #25
                      Yea theres the blue/white (remote) plain blue (antenna?) But to the solid blue it turned the amp on but nth came out the subs
                      Ef hatch sold
                      Db7 blew up
                      Em2 sold
                      Db1 traded
                      • #26
                        I have it hooked tl the red & it turns the amp on&off with the radio so i think im good i hope lol
                        Ef hatch sold
                        Db7 blew up
                        Em2 sold
                        Db1 traded
                        • #27
                          atatch it to the blue/ white remote that should fix your problem but if your happy the way it works you should be ok
                          • #28
                            When its hooked up to the blue/white the amp doesnt turn on unless k run a wire from remote to 12v on the amp
                            Ef hatch sold
                            Db7 blew up
                            Em2 sold
                            Db1 traded
                            • #29
                              do you get any out put the way you have it now cause i know you said it turns on and off
                              • #30
                                Run the remote wire bro.. thats the 1 that should be ran man, u'll sleep better at nite doing it right
