no power to amp
  • no power to amp
    Had a single 10 with matching amp in my car. Was working fine till the other day it just stopped. I got back in my car a few mins later turned it on & it worked for a lil bit then stopped again. Thought it was the amp so I picked up new subs & amp. Everything is connected the correct way but the lights on neither amp turn on. Any suggestions or ideas why the amp isn't turning on
    I've had numerous amp & sub combos in this car & never had an issue till now
    Ef hatch sold
    Db7 blew up
    Em2 sold
    Db1 traded
    Ek fodo daily/project
    ur power wire connector to the fuse is prolly loose
    D and G auto member #5
      Thought that too. But I took it out & redid the power wire
      Ef hatch sold
      Db7 blew up
      Em2 sold
      Db1 traded
        There's only 3 power connections to an amp, 12v, remote n ground check all 3 make sure there's voltage goin threw and a good ground...
          My boy just told me that the remote wire might be bad is there anyway to check with out a voltage meter
          Ef hatch sold
          Db7 blew up
          Em2 sold
          Db1 traded
            make sure you have all connections are proper.. grounds usually act up. just take your time and redo all the wires.... if its a remote wire problem quick test is to just take a small strand of wire and jump the 12v to the remote turn on if it does not work check your ground . make sure you have voltage from the positive i seen people try to do this and never had power from the batt. if you have any questions just ask.
              Ive got the perfect solution to all of those problems..... Dont install them in the 1st place stock speakers are good? Y waste the trunk space and battery life -__-
              But good luck figuring it out
                Personal preference & I still have plenty of space.
                thanks tho
                Ef hatch sold
                Db7 blew up
                Em2 sold
                Db1 traded
                  Ef hatch sold
                  Db7 blew up
                  Em2 sold
                  Db1 traded
                    I ran a wire from 12v to remote & the blue power light came on but the subs don't do anything
                    Ef hatch sold
                    Db7 blew up
                    Em2 sold
                    Db1 traded
                      Any ideas my brother in law is possibly bringin me new wires but not sure
                      Ef hatch sold
                      Db7 blew up
                      Em2 sold
                      Db1 traded
                        With a wire running from remote to 12v it works fine
                        Ef hatch sold
                        Db7 blew up
                        Em2 sold
                        Db1 traded
                          Ef hatch sold
                          Db7 blew up
                          Em2 sold
                          Db1 traded
                            New wires didnt help
                            Ef hatch sold
                            Db7 blew up
                            Em2 sold
                            Db1 traded
                              If new audio cables didnt work the pre-amp or the rca preouts shit the bed, havnt seen it in the past but i had a poineer last yr do the same thing to me.. i swapped out decks and everything came back to life. Took the deck back to best buy the next day.. I guess this new stuff they make these days is junk now
                              96-ek hatch b20vtec - daily
