i need free help wit car audio!!
id look inside the box....then id try diff rca...cable could be broken internally....also check the actual input output jacks on the radio and amp make ure there is no play or internal break....grounds? sand the spot u got it bolted to for a better conection. do the same for the speaker input too make sure nuthin broke connection..its sumthin stupid u just gotta take ur time and find it.
Is ur amp turning on if it is i no wit my subs i had to flip the wires to one speaker like one is regular positive positive neg neg but my other sub would have to b pos to neg and neg to pos cuz wen i put them pos pos the bass wouldnt hit until i flip one of the wires and after that they hit hard as hell
try flipping the rcas maybe they are backwards i've made that stupid mistake in the past that would cause that the other thing i can think of is go to walmart and buy a new set of rca's for about 10$ and swap them out if the amp gets power and there is no signal it has to be either the rca's or the speaker wire or your sub is bad
