sub killin battery
  • #31
    you dont necessarily need a whole new wire kit just buy the wire knu koncepts has great deals i bought 25ft of 4awg for 30$
    • #32
      50' of 0g 37$ bulls audio on sale
      • #33
        damn thats a hell of a deal is it good stuff?
        • #34
          oh yea, and its a nice color blue wre too and it comes on a spool/ dope
          • #35
            Originally posted by anthonyb5s4 View Post
            x2 but if the headunit is causing the amp to stay on then thats not gonna solve the issue make sure the red wire to the headunit is connected to a constant source of power and the yellow wire is conntect to a source of power that turns on with the ignition, if both are connected its gonna cause the headunit to stay on even when the car is off which causes the amp to stay on which will kill your battery
            got it switched..yellow should be hooked up to a constant 12v but the red needs to be an accessory 12v and this does sound like the problem to me..and for caps get 1 fared per every 1000 watts wont fix your problem though
            • #36
              yea now i have prob with either amp or sub now neither work but amp turns on wen headunit tunrnson and fan kicks on in amp and sub dont kick on and worked on m,y other amp
              • #37
                go simply discount the power wire from amp, let it sit over night and see if your good in the morning if not then u have a head unit problem, chances are its going to be a problem with the head unit seeing as the amp is only as good as the head unit in telling it what to do as far as turn on or stay off , also drive the car to advanced auto or auto zone and have your battery and alt tested its free let us know how u make out !!!
                EM1-860-CTmember..1...
                J-SWAPS ....860-457-8335
                • #38
                  I had my amp tested today by local audio store and I got sold a broken amp and its no good will be up to $150 to fix so imma sell it fir someone to fix who can and im buyin a planet audio 2200watt for $150 from best buy
