Radio and clock
  • Radio and clock
    0k so i put my radio in an the yellow cable dont have power is suppose to have consistent power but it dont and also everytime i turn the car on an off the clock losses the time
    i have a 93 civic ex wat can it b?
    try reading this.... this guy had the same problem.
      check the fuse under your hood. it should say radio
      ~StayinFRESHSINCE1982~
      SPUNKY MONKEY CREW MEMBER #1
      203 CREW MEMBER #33
        ima do dat in the a.m
          ok
          203 CREW MEMBER #33
            no fuse under hood that says radio but under the dash yea...but is good an it still do the same thing
              it doesnt say radio on it, lemme go check my car out foryou... brb
              203 CREW MEMBER #33
                lmk bro
                  i got the same problem!!!!! anyone figure it out? or know where that harness goes to so that i dont have to take the dash out to find it?
                    yo i got the same problem.. Somehow the wire shorts out wicked easily. I ran a wire from the battery to the power wire, that way there you get consistent power.. run it right thru the firewall... problem fixed!!!!
                      i fixed it by changin th fuse lol
