HELP! fog lights wiring for EG
  • HELP! fog lights wiring for EG
    Yo it was pretty much pug and play but from the switch harness there are two wires extra and there is still no power running just pluged in the lights and the grounds so there is two yellow wires that are on the same clip and theres a light blue single wire that looks like it plugs in to that battery i know it is something dumb i just dont want to ************ them up
    bump cause im going to need to know the answer to since i have to wire mine up as well
      you could delete the switch by jus hooking them up to a switched wire kinda like day time runnin lites . theres the cannon plug full of yellow wires w/ black stripes get ur power from that .... then ground the grounds and everytime ur keys on to the 2nd click they will b on .. if not jus hook the power to the battery nd then through the switch nd to the lites then ground the grounds nd u should b good
