Need Advice : B20v vs LsV*
  • Need Advice : B20v vs LsV*
    Okay , idk if their another thread with the Same title , but I'm lookinq for the good & bad on both setups & which will come out good overall , , which one will be worth buildinq && need advice , what's kind of pistons & rods & etc ,should go on a b20v or lsv build . .
    & Gonna be Usinq a B16 Head . My Goal is prolly to make 180-200whp . .
    *FYI :Late Night , can't sleep & bored , so gotta do somethinq LOL . .
    98Ex DD EJ8 ROADRUNNER
    i had a jdm b20 block with a gsr head with sum skunk 2 pro 1 cams and 310 injectors skunk 2 intake mani and 68 mm throttle body and real hy tec big tube header and a type r tranny and i made 208.....an that set up with tune an all ran me 2,300
    fuck fake friends crew member #1....i love my h8terz, an those that talk with no cars!!
      ^^ Not bad , cause im thinkinq about spending closed to that . . .Thanks for the input !
        I would go with b20
          ^ Thanks Santi & I deff Will . .Lookinq for a B20 Block :)
            B20v if your doing all motor
            TURBO 2001 IS300
              The B20 is really just an LS with a bigger bore, which means thinner cylinder walls. They have the same stroke, just a different bore which gives the B20 more displacement. If you're just going with a stock setup with bolt ons then I'd say to go B20v.
              B18B1
              Bore: 81mm
              Stroke: 89mm
              1834cc
              B20B
              Bore: 84mm
              Stroke: 89mm
              1973cc
              same stroke w/ larger bore = 139cc added displacement to the B20
                bump thats what im about to run just looking for parts now. lol
                  Thanks People , Made up my Mind .
