I need to get my del sol running this weekend. I am doing ITB's on my Ls/V. GSR head. I bought OBX ITB's. I have a few questions if anyone has ever done this install and the car ran after... First things first. I have a P72 computer. Can't afford an S300 or AEM right now. Is it possible to run it with a stock ECU? NEXT: Idle air control valve.... Do I just run the coolant lines without it? And Vacuum lines... I think I can take care of that with a vacuum manifold. BUT I would have to order one, so Can I use some "Tee" fittings and an "Elbow"? Thanks if anyone can help me. P.S. I just started my job and need a car. P.P.S I DID order a Skunk 2 intake manifold. BUT I honestly wanna use the ITB's. I was running a supercharger but ended up killing 3 blocks so I sold it.
Ls/V Doing ITB's Anyone ever do ITB's on B-Series? Need help with vacuum lines+more
Thats the best idea you can have. If you are sitting here trying to put itb's on but run a stock ecu you obviously are not ready. And you don't run a iacv when you run itb's. You take it out. Your tuner will set it up in the tune and dial in everything to make it idle fine without it. Itb's are awesome. But pointless if not done right.Money ain't a thing! Crew Member #1
