wat up ctvtec.. im building a allmotor gsr stock 81mm sleeves have a full built head all skunk2 valve train pro 1 cams... wat compression ratio would be good thnking bout jdm itr pistons and rods, or eagle rods with 11.5-1 comppression.. thanx
quick question
Originally posted by kasperferio View Postwat up ctvtec.. im building a allmotor gsr stock 81mm sleeves have a full built head all skunk2 valve train pro 1 cams... wat compression ratio would be good thnking bout jdm itr pistons and rods, or eagle rods with 11.5-1 comppression.. thanxGreatness is only 1,320 ft. away!!!
11.5 is alright, I think 93 octane maxes out at around 13:1 compression. You'll also want to clay the motor for valve clearance.
Higher compression isn't going to significantly raise your peak power, most likely will increase midrange if tuned properly.
Originally posted by STITCH View Post11.5 is alright, I think 93 octane maxes out at around 13:1 compression. You'll also want to clay the motor for valve clearance.
oh man... not that im stealignt he thread. but im going with practically the same build. i dont know what im doing for the head right now, but the block is done, with a .25 bore usdm itr pistons on stock rods and crank in a b18c block... what should i do for my head?~StayinFRESHSINCE1982~SPUNKY MONKEY CREW MEMBER #1203 CREW MEMBER #33
please make the subject title a little more specific next time*Former CTvTEC Moderator
DC Squad Member # 604
203 Crew Member #9
203 Buffet Crew Member #7
DC Parts For Sale
EG Parts For Sale
12.5:1 compression ratio will compliment the cams that you are going to use . anything less and you will suffer in the lower rpm range. You should always design your bottom end around the cams that you are going to use. The smaller the cam the lower the compression. Big cams tend to bleed off compression at lower rpm, requiring more compression to maintain good Transient Response. Under-camming an engine will require better fuel because the cylinder pressure will be too much for pump gas, depending on the compression chosen.(860) and beyond
#DavesTuning 8608050968
